Show only
Search instead for
Reverse joint direction when using "Animate Model"
When using "Animate Model" to see the effect that a moving joint will have on an assembly, it would be nice if you could select a "checkbox" to reverse the animation direction. At the moment, my walker is walking backwards... 😞
Thank you for posting your idea! The idea is now 2 years old and does not have many votes, so we are going to archive it. If this is still important to you, please make a new post with the idea included. You can follow the idea submission guidelines here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
