Cam - Default settings for toolpaths
How hard would it be to let us select options and save them as DEFAULTS? I'd like to use Wear comp on EVERY contour toolpath I run. It would be nice if I didn't have to repost and edit the entire program because I forgot to select the checkbox, hence the idea about selecting USER DEFAULTS.
John
1 Comment
HughesTooling
If you setup an op with the setting you want as defaults you can right click the op in the browser and select Make Default. While editing an op you can also click any number field and select make default. Only headache is setting options and check boxes, these have to be set either using the first option or right click a number field and select Make All Default.
Mark
