CAM - Allow Negative Linear Lead Out Distance
I need this cutter to make the cut and then reverse back to the lead in position to retract out of the part.
In theory, if I use a negative linear lead out distance it would work but fusion doesn't allow negative linear lead out distance.  This is a 2D contour tool-path.  If there is another way to do this, any suggestions would be appreciated.  Thanks
