![Hole improvement.png Hole improvement.png](https://forums.autodesk.com/t5/image/serverpage/image-id/185535i2BC126885F41E783/image-size/original?v=mpbl-1&px=-1)
1. Multiple holes that's created from the same multiple-holes command should be grouped together by default
2. Individual/selected holes is able to "break" away from the group in a similar way as reordering the browser tree, holes that's of similar features should be allowed to grouped together as well.
3. Once the grouped hole is selected in browser view, it'll highlight all the respective holes in the model view
4. Changing the hole will affect all holes in the same group
Why vote?
Imagine if you have 100 holes in your model (and it's actually a group of 20 M4 C'Bore, 20 M5 C'Bore, 60 M3 Holes), and you needed to change the M3 holes to a (20 M3 Holes + 40 M4 Holes), change the M5 C'Bore size to M6 C'Bore. The current solution now requires you to individually update all 80 holes! That's is just too inefficient and time consuming.
Please make it happen, thank you!
