Bolted Connection for Fusion
Hi All,
Please let me take an advantage of this great forum to get feedback to an idea of doing a Bolted Connection tool for Fusion.
Here is a link to video that demonstrates the proposal: http://youtu.be/7ev8vtVPY3A. The idea is simple: provide one click solution for modeling productivity. Simple UI and workflow optimized for Designers. Quick geometry generation, but no BOM (Bill Of Material) data.
Bolted Connection
I’m leading a small development team in Autodesk that just joined the Fusion family to help to make it even more successful. There is nothing better than getting feedback directly from You – Fusion users. Please take a look at the video and let me know your opinions, suggestions and thoughts. I would really appreciate it.
(If that kind of direct communication between development and customer community would be interesting to you I may be setting up a blog here – we did also a proposal for Gear tool that would quickly produce gears with exact geometry ready for 3D printing and some other interesting stuff.)
Thanks for your time,
Vasek
62 Comments
petrara
Maybe if the feature is made truly parametric, with the possibility for user-made bolts to be used, then would be no reason for restrictions.
All it needs is a set of rules to follow if the user wants to build a special type of bolt. This technique is by far new... many other software use it.
Jacob553
What happened to the bolted connection?
