Blend Curve Needed!
Blend Curve Needed!
Rhino's "Blend Curve" is heavily used by myself and colleagues, and I don't want to sketch in Fusion 360 with out it.
Could you please create that for Fusion 360?
- R
3 Comments
Not only that, but I'd like to see several object driven curve options that you can create outside of "sketch." When in patch mode, the closest thing to Rhino at the moment, you're looking for speed.
Rhino has 2 tools that are Extremely similar. Blend, and BlendCurve. Both create very similar curves, but realistically, they should be joined into one tool in Rhino, with just different options.
You can choose to be position, tangent, or curvature continuous to either surface, or both. But then you can also choose the amount of influence each side has. That shouldn't apply to position though. Position obviously has 100% influence on the curve end.
colin.smith
This item has been archived due to a lack of votes. If you feel this item is important feel free to create a new idea station item.
colin.smith
Status changed to: RUG-jp審査通過
