Joints that can be 'locked', e.g. revolutes, should have a toggle-able icon in the browser. At the moment the only way to tell if a joint is locked is to either look for a tiny padlock icon in the drawing, or to right click each joint in the browser one by one until you find the one that says 'Unlock'. I wish there was a button right next to the joint item that I could just toggle with a click of the mouse.
And yet joint items in the browser enjoy a whole "Edit joint limits" button, which I believe is not as frequently used as the lock/unlock command. Lock/unlock is a very common action when you need to prevent a complex assembly from going bananas, so if we must have one button there I'd much rather it be the lock/unlock button, however that still wouldn't be ideal. Here is a more sensible suggestion:
I hope that makes sense! Below is a crappy mock-up I just did. Joint 'First cog rotation' has both limits and is locked:
