Basic Dimensioning Changes
I am well aware that the drawing side of Fusion is need of much attention but I have a request to fix two really annoying aspects.
  1. When adding a dimension to nonparallel objects the dimension should be set to horizontal/vertical as the basic default. Not the align that makes you drag around until the dimension snaps to horizontal or vertical.
  2. I can think of absolutely NO reason why I would want to dimension any part of a Hole Center Mark. If I try to dimension from a center mark to an edge, it often tries to select the extension of the center mark to dimension. That is just wrong!
