Please add The option to disable selecting face or feature in Fillet command
Ever since the new face & feature filleting was added, the filet command has slowed down a grinding halt when working on certain parts.
When I try to filet an edge, it will flash between the edge and the faces around it and cause the program to become painfully slow.
In addition to this, I generally only want to fillet an edge, and having the ability to select a face has actually slowed down my workflow, since I will every once in a while accidentally click a face, and have to wait for the fillet to fail to continue.
Having the ability to click a box in the fillet command window to choose to only fillet edges, or only faces would be very helpful for me.
Thanks!
2 Comments
dwboyd
In addition, please make it easier to NOT select everything but the sketch entity you are trying to select! This behavior is incredibly frustrating, and it's modal, so every time you try to edit or use a sketch in an operation (feature), it defaults to selecting everything under the sun, except the sketch entity you are trying to select. Unbelievably frustrating.
When the command fillet select a surface instead of a edge creates stress for me.
