Autodesk drawing edit ( not block) DWG or DXF for elaboration cnc machining parts
often designed mechanical parts for preparation of manufacturing cnc cutting for which a dxf or dwg file that provides inventor files in the drawings which are then easier to edit in AutoCAD is required
