Auto zoom when create and edit sketch
It would be more intuitive if when
  • creating a sketch, window is automatically zoomed to fit (the component), so you can easily select the origin planes - since these are the most common used sketching planes - or any other planes.
  • editing a sketch, it would be better if the window is zoomed to fit the sketch. (Currently it seems to auto zoom to the middle of the component, which is quite annoying when I'm already zoomed to the sketch but once I click edit sketch, my window view automatically moved to somewhere else.)
Also please make it possible to set sketch option 'slice' to be selected by default.
2 Comments
TimeraAutodesk
Status changed to: RUG-jp審査通過
Thank you for your idea - this is getting archived due to lack of votes. Ideas with 10+ votes within a month are reviewed by the Product Management team for future consideration. If you feel strongly that this is needed, please resubmit with more detail on why you think this is valuable to Fusion 360 users so that the idea gathers some more support from the community.
now this idea is archived, can't I vote for it anymore?
I was about to post exactly the same idea. Quite annoying when you work on a long profile, with a sketch on the end that Fusion automatically zooms in to.... to what? far away from your sketch anyway, even if you zoomed in to the sketch yourself before starting to edit it.
Exactly like the idea submitter described actually.
