Assembly drawings
Assembly drawings
I would like to see the ability to select a Subassembly to make a drawing. currently the workflow is to select all this components in the subassembly to make the drawing. I made the effort to make them in an assembly for a reason. I would like to control that subassembly.
4 Comments
TimeraAutodesk
Status changed to: RUG-jp審査通過
Hi @Anonymous,
Thanks for your post. You can do this today, actually. From the 'Create Drawing' dialog, deselect "full assembly" from the Reference section, and simply click on the top-level of the subassembly you desire from the Canvas Browser. This will select all of the components in that subassembly for you to create a drawing of.
nduff3AYZ7
Observer
I see how to do it, thank you. but you can't do it form the canvas.
TimeraAutodesk
What do you mean you can't do it from the canvas? You can select or multi-select any components you want from the design directly in the canvas or from the canvas browser to send to a drawing. Are you referring to a different workflow?
Yes I am. Typical the purpose of having a subassembly is that I am going have its own drawing for fabrication purposes. I understand that I can select all of the components in individually in the canvas. However, I want to select the subassembly directly from the canvas. I would just give its own selection toggle. For example, Full assemble, sub, or component.
Nick Duff, MEng
Mechanical Engineer, Simulation Lead
1901 Nelson Miller Parkway​​
Louisville, KY 40223
1-877-438-2741 ext. 1165
www.AdvancedSolutions.com
