Allow Reposition of Sketch Constraints Glyphs/Icons
Need to be able to drag them to another position.
3 Comments
Yes, this. I am working on sketch with 12 concentric circles and 4 different radial line patterns, all around the same center. I can easily move the attendent dimension lines so the circles can be refined to their final dimensions. But the constraints and pattern icons are impossible to select since they are on top of each other. Yet another example of why you need to break out the contents of a sketch in a list-/tree-based arrangement so we can positively and easily select them. Not having a nested history list for the sketches is just plain lame, which then drives this need. Being able to move the constrain icons to separate them for selection is not a complete solution to this problem.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
