Additional Physical/Mass Properties
Ability to generate additional Physical/Mass Properties of a model (e.g. to be used for Manufacturing, Quality Inspection, CAE, and model integrity validation purposes when importing to or exporting from Fusion 360). In addition to the physical properties already calculated by Fusion 360, Moments of Inertia and Center of Gravity (Center of Mass) should also be included. Also, the ability to export all physical properties to a textual format that can be imported into a database, or compared to physical properties from original model already stored in system database to validate design integrity of any derivative models.
24 Comments
promm
Status changed to: オートデスク審査落選
kdeuler
Speaking of mass and center of gravity: Please see my suggestion just posted for adding a gravity vector:
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/add-a-gravity-vector/idi-p/6319609
keqingsong
This is now implemented in the May 25 Update!
http://www.autodesk.com/products/fusion-360/blog/may-25-2016-update-whats-new/
Second phase will include a visual representation of where Center of Mass/Center of Gravity will be on the model itself so that you can measure to it.
Any idea when the second phase will be? Could use that COG marker right now 🙂
