Add Server value to CAM Task Manager dialog
In Inventor HSM & HSMWorks, you can right click on the Header of the grid, and turn on the Server column. This in turn will display the Host Name for the machine running that task. For some reason this is missing in Fusion 360, which makes it very awkward to see in real time where jobs are running and if Distributed CAM is operating correctly or not.
2 Comments
fonsecr
Thanks, it was a bug. Only Server was missing from the options. I fixed it for the next release.
jeff.pek
Status changed to: オートデスク審査落選
