Add ability to select Third Angle Projection for Drawing views
I have seen reference to this request elsewhere in threads that are marked Implemented, but this feature is still missing.  Auxiliary Views always appear as first angle projection - this is not the norm in many companies drawing standards or industries.  If implemented, the default method: First or Third Angle should also be in the user preferences, as well as selectable in the Edit View dialogue or set as part of the Drawing Sheet properties.
2 Comments
TimeraAutodesk
Status changed to: RUG-jp審査通過
Hi @wilwyn, I'm archiving this because this functionality already exists through the Preferences panel. You have to choose a standard first, then you can override all the settings of the standard, including first or third angle projection preferences.
wilwyn
Thanks, that is exactly what I was hoping for. Can't believe I didn't spot the option in Preferences, although quite few others also seemed to think it was a missing feature.
