Move tool
Move tool
Until a recent update, I could combine multiple move types in one operation. So I could move a part to its approximate location using Free move, then zoom in and finish fine positioning with point-to-point (e. g. without having to first zoom to object 1, pick the first point, zoom out and pan to destination, zoom in there and pick the scond point...).
In the new version, when I try to switch the move type during the operation, the object being moved returns to its original location. To do what I used to do before, I have to close the Move window and then open it again. Putting it very mildly, this is extremely annoying.
The original behaviour was much better in my opinion. If returning to original position is really something that is necessary (it certainly is not for me), I would say a local undo within the move dialog would make more sense.
5 Comments
HI!
I totaly agree with you, I used the moving tool the same as you and this is very annoying What i also noticed was that When using the point to point moving tool i remember to be able to select faces and lines to move parts, but not any more? I know you can do by using the align command but I was kind a used to using only the moving tool.
Are you guys having problems using the midpoint on objects and lines when using point to point as well? Also I agree being able to free move,rotate, and then point to point was so much nicer with the previous move command.
keqingsong
Can you post this in the main forum to see if this is a bug or not? Most of our developers are there and it's better for them to see what you're workflow was/is with the movement command enhancements.
jakefowler
Status changed to: オートデスク審査落選
Changing to Accepted - we'll be re-adding this capability soon.
For now, after the Free Move stage of the move, if you hold the right mouse button, drag up and release, it will directly Repeat the Move command, which will essentially apply the first step and allow you to switch types and perform the point-to-point move. This should make this workflow easier than manually re-invoking the Move command.
keqingsong
I believe we have this fixed last year. Marking it as implemented.
