Adaptive X Y Z Delta Axis annotation
Hey Fusion Developers,
It would be great if the X Y Z Delta measurements on the respective axis would rotate around its axis, depending on the direction of view.
Whenever i measure the distance between two points with the 'measure-tool', the X Y Z Delta measurements are written in a certain plane of the origin coordinate system. If i look from another side/angle/direction, i look on top of the measurement. being that a 2D entity, it vanishes as a line in the same colored Delta axis line. (see attached screenshots)
Can you make these measurements writing planes rotating themselves to be as perpendicular to the direction of view as possible?
That would be great...
Thanks!
2 Comments
Mike.Grau
Hi @ninolemann,
Thank you for posting your idea.
I have voted for it. Let us gather more attention for your idea
that it has greater chances to be implemented into Fusion 360.
Thank you
ninolemann
Anybody?
Come on, you guys, rotating your model for eventually reading the measured distance is really annoying, and i guess this is a quick fix, too.
Please vote for that one!
Thanks!
