active sketch selection through bodies,
Im not sure if this is a bug, or intentional,  but if I create a sketch on an origin plane, within a body,  when I try to select part of the sketch, I end up selecting faces on the body rather than the active sketch.
I think when a sketch is active,  it should be selected first. if I want to select part of the body, I should be able to move off the active sketch and select any part of the body.   This is also needed when I want to dimension part of a sketch to part of a body.
If I am overlooking something, please let me know 🙂
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
