This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
active sketch selection through bodies,
Im not sure if this is a bug, or intentional,  but if I create a sketch on an origin plane, within a body,  when I try to select part of the sketch, I end up selecting faces on the body rather than the active sketch.
I think when a sketch is active,  it should be selected first. if I want to select part of the body, I should be able to move off the active sketch and select any part of the body.   This is also needed when I want to dimension part of a sketch to part of a body.
If I am overlooking something, please let me know 🙂
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
