A Single Dialog Box for all the Project commands - UI Change!
Hey guys,
The Project commands (5 in total) are a very essential and basic set of tools in our daily design process. Even thou some Project commands are used more often than others, I think they all should be under a Single dialog box and inside the dialog box, the first option would be to choose the Type of Project command is needed.
  1. We save space in the Sketch menu.
  2. Easier to reach and click one command and eliminating another sub-menu.
  3. One shortkey ("P") to open the main dialog box and separate shortkeys for each Project command, which will open the main Project dialog box with the Project command type radio button selected.
I hope it makes sense. Please let me know what you think.
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Need a new computer? Fusion 360 Hardware Benchmark: TESREG.com
Check out my YouTube channel: Fusion 360: NewbiesPlus
