A proposal about multi-Axis Contour _ Geometry _ Curve Selections
Hi, my name is Sangho
It's really uncomfortable select the curves at multi-axis Contour. I think that could be like other commands.
Other commands has a stepover, stepdown. But only multi axis contour has no stepover and stepdown.
And even If i made a lot of curves, it is really hard to select each curve. I propose to atuodesk team about this situation.
It will be more comfortable, if i select only first curve and end curve and control the stepover, stepdown parameter.
3 Comments
@Anonymous
What you are looking for is being developed as we speak.
It will be called blend and is something like a multi-axis morph operation.
Oh I want to use it as soon as possible.
Thanks 🙂
Thanks 🙂
