2D Chamfer Compensation Options in CAM
The 2D chamfer operation in Fusion CAM does not allow you to select a left or right compensation for toolpath generation.  The toolpath defaults to climb milling which is usually great unless you use a Mirror Pattern.  When using a mirror pattern the toolpath compensation is also mirrored which only allows a conventional milling chamfer toolpath.  With the aesthetic nature of most component chamfers the option to insure climb milling would be an important option.
Brandon Shannon
1 Comment
colinNPU8N
I have the same problem, I need to climb mill a mirrored part...
