Generative Design Outcome Cost Estimation
dvd.mlm
Autodesk Autodesk
dvd.mlm
Generative Design Outcome Cost Estimation was announced in our October roadmap update.
In summary, using anticipated annual production volume as an input, you now get insights to the anticipated part cost. This allows for more thoughtful trade-off analysis when evaluating cost and performance using generative design.
Discussion Thread Feedback
Try this capability and then use this thread to share overall feedback. Let our product teams know your thoughts about what you like and what can be improved?
Survey Feedback
Take a brief survey that includes a few more questions about cost estimations.
Take the survey now
Thank you,
Fusion 360 Product Research Admins and Generative Design Teams
dvd.mlm
SteveCox3D
Now that aPriori cost estimation is formally part of the Generative Design options it would be good if the material library indicated which materials are supported for cost generation.  Whilst in preview I got multiple warnings in the Pre-check area that the materials that I'd chosen were not supported for cost estimation.
If cost analysis is an important parts of the evaluation phase of a Generative Design I would want to ensure I pick a full range of seven materials that are supported for that functionality.  At the moment it is guesswork as to which materials will work with this new function
dvd.mlm
Hi @SteveCox3D,
See this help article below and jump to the section about "Fusion 360 - aPriori material mapping".
https://help.autodesk.com/view/fusion360/ENU/?guid=Fusion_GenerativeDesign_concepts_cost_estimation_...
We are working on additional future improvements here.
David
janusl
Thanks Steve. Would you prefer to keep both the pre-check and a kind of “label” for supported materials for costing or replacing the pre-check with the “label” ?
PS
Currently, you can find a full list of supported materials for costing in the Help: http://help.autodesk.com/view/fusion360/ENU/?guid=Fusion_GenerativeDesign_concepts_cost_estimation_h...
Leslaw Janus
Principal Experience Designer
SteveCox3D
Thanks David, it's good to see that list.
I was thinking of an idea where in the Material selection dropdown there's a check-box to select "Cost Estimation" of the study, which would then automatically filter the material list to only those which are supported for this function.
Reading that help article though has pointed out that supported materials are also mapped to the manufacturing method, so I'm not sure then how you'd avoid a pre-check warning example of "AlSi10Mg is not supported for Die-casting. The manufacturing cost will not be generated".
I have a mindset for a Generative study that I want to be seeing either a green tick or a minimal number of amber warnings in the pre-check icon to maximise my chances of a successful outcome.  The aPriori cost estimation has dramatically increased the number of amber warnings I'm seeing which may mean I miss something more important, which is what has prompted my post about trying to improve the situation.
Best regards, Steve
SC_Precision
I am extremely interested in learning more about this function but find nothing to get kicked off, and nothing on YouTube even.  When attempting to give it a try, I get garbage (which , according to the famous saying - "garbage in garbage out!".   How do I learn not to put the "garbage in"?  Thanks for any advice!  (I don't think the xometry add-in is appropriate but is that the default now and not apriori?  I don't think xometry will allow me to cost analyse certain features I program in Manufacturing.  I want to start from a casting, and come up with a cost for the machined part.  I believe from what I see xometry can quote a casting OR a machined part (?).  THANKS!
