when stacking circles it automatically groups them
robert.flammia
Message 1 of 9
robert.flammia
Pardon my lack of knowledge and I'm sure its something that's is incredibly simple but I can't figure this out.
I'd like to create two circles with different diameters that have the same center point, then I want to move one above the other to create a tapered cylinder, but when selecting the move tool it moves both circles together, I attached a video of what I'm running into.  The first part of the video shows what happens when I stack them and the second part is just for illustration of what I would like them to do individually.
- Bobby
Replies (8)
Message 2 of 9
robert.flammia
Message 3 of 9
jeff_strater
when you create two circles with the same center point, they are constrained to be concentric.  This really means that they share a single center point.  To move one without moving the other, you need to delete the concentric constraint:
There are lots of other ways to do this.  You can extrude a single circle with a taper angle, you can create two separate sketches, or use Revolve.  But, your way is just as good...
Jeff Strater
Engineering Director
Message 4 of 9
etfrench
Fusion 360 lofting doesn't work like that.
  1. Simply create an offset plane at the top height of the truncated cone you want to create.
  2. Create a sketch on the plane.
  3. If your original circles' centerpoints are on the Origin, then draw the smaller circle at the new sketch's origin.
  4. If not on the Origin, then project the smaller circle to the sketch.
  5. Loft between the two sketches.
You could also just extrude the larger circle and specify a taper.
Another method would be to extrude the larger circle, then do a chamfer.
ETFrench
Message 5 of 9
jhackney1972
You are creating two concentric circles on the same plane "in the same sketch", so they are both in one sketch, of course they will move together.  Create a second plane, above the first, and make a second sketch on it, then loft between them.   If you just want a taper cylinder, do a single sketch, and extrude it with an angled side is the easiest method to get a tapered cylinder.   See Screencast (no sound).
John Hackney, Retired
Message 6 of 9
etfrench
Actually, you can loft between items in a single sketch.  As @jeff_strater pointed out, removing the Concentric Constraint allows the circle(s) to be moved off of the sketch plane.  The loft command will work with these circles.
ETFrench
Message 7 of 9
TheCADWhisperer
... to create a tapered cylinder
A cone?
Revolve.
Always use the most primitive geometry possible.
Loft should be disabled until user has 6mths of experience.
Message 8 of 9
chrisplyler
LOL we'd lose half the newbie traffic to this forum!
Message 9 of 9
robert.flammia
Thanks Jeff ! that did it, thanks all for the replies and advice
