I'm a 3d printing newbie. I've modeled in the past and getting back into it with Fusion 360. I'm looking for direction from you guys...
what tools would you use or know of any tutorials I should look at for creating stuff liek this?
Or perhaps more interestingly... something like this.
The natural flowing organic shapes (almost bubble like quality to it) is really interesting, but seems like it could be a pain to apply to an entire plate, body or component...
I was curious if anyone had any input of where maybe to start with learning to create and apply this technique to some of my designs.
HI @Anonymous,
Welcome to Fusion 360.
Because of the organic shape, I will go with T-spline (Free Form modeling). But, in order to use T-spline correctly, make sure you have all the basics in place.
This will give you a good heads start:
http://help.autodesk.com/view/fusion360/ENU/?learn=sculpt
If you are not sure about something, please don't forget to ask!
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
Thank you. I appreciate it very much.
I followed those tutorials and see what you mean. That would definately be the way to create the "basic shape."
I think the part that I'm struggling to grasp is how to make the "holes" in this. I'd think modeling each 'hole' would be a cumbersome approach.
Is there a sort of "skin" approach to modeling in Fusion? I'm thinking how in other applications I've applied a bump map to create texture to a plane. I wasn't sure if that sort of logic applied to Fusion. For instance if you wanted to a modeled "fabric texture" to a plane or a bunch of tiny triangles to create a slight "grippy" styled pattern to a plane. I'd think that same logic might apply to these "holes" as I'm wondering about applying an entire textrure or lack of face to an entire shape.
Does that make sense?
Yes, it does make sense. But the guys who can help you with that are @PhilProcarioJr and @cekuhnen. They are both T-spline experts.
I'm sure you will hear from them soon 🙂
Cheers / Ben.
Ben Korez
Facebook | YouTube
@Beyondforce Rule number one - SO OVERRATED hehehehe
(kidding of course)
@Anonymous
There are two geometry types you have, linear and organic
first image: you can use a 3D sketch with only lines and create those planes
later you can
thicken the deign
on each planar face create a sketch offset as needed and extrude through
second image: that one uses a voronoi like structure - so for sure a T-Splines candidate
but the tricky part here is that this is not a planar surface but an bend volume
so the fracture or cell structure you might have to model by hand.
Fusion T-Splines offers a nice Pipe command that blends between pipes
you can later adjust those cross sections easily to sculpt more
@PhilProcarioJr Do you have a different idea? This type I would do external.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
@Anonymous
Honestly, what you want is going to be very cumbersome in Fusion. The cell look is easy using the fracture plugin and the pipe tool in the sculpt environment, but to actually model fabric or holes all over the surface, or anything repeated all over the surface you might as well give up on because Fusion can't handle that type of geometry unless it is an extremely simple model. Fusion support normal and bump maps for renders only and doesn't support displacement maps. Your best to model the forms in Fusion then use MudBox or Zbrush to add the surface effects. Holes all over the surface use Blender. You can try if you want, but your wasting your time on anything but the cell look you originally mentioned.
Just my 2 cents...
Phil Procario Jr.
Owner, Laser & CNC Creations
Your on the right path, I use the fracture plugin and the pipe tool in the sculpt environment, so your correct in how you do it. The reason I use the fracture plugin is because it saves massive amounts of time and looks very natural. It can all be done by hand though. The rest of what he wants is not possible with Fusion alone.
Phil Procario Jr.
https://apps.autodesk.com/FUSION/en/Detail/Index?id=2750937976163552948&appLang=en&os=Mac
does this one work inside T-Splines?
@Anonymous
I second Phills point that the organic looks is quite hard to made without proper flow or bend tools which Fusion
currently (hint to devs 😉 ) does not have. This is also a pretty specialized case.
But I think you can do it in T-Splines with the pipe command - it will however require some time to model and sculpt.
You can start with the basic approach creating a flat ring band with the network (possible cells )you want
then pipe it with a low res mesh
then adjust everything as desired
Claas Kuhnen
It only works in the model environment on solid models but that's what makes it a perfect fit for this kind of work. Once it is run on a solid you can select the cuts in the pipe tool in T-Splines.
That's how I made this:
Phil Procario Jr.
This has been extremely helpful. I'm going to take this all in and see what I can create. Thank you!
