- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
- For example tall doors need 3 hinges and and shorter doors need 2 hinges. How to make this parametrically using Fusion 360 parameter functions.
- Use the Sign(expr) which returns 0 if negative, 1 if positive
- Let's say a door shorter than 1200 mm, the "Rectangular Pattern" quantity should be 1. Which is basically rectangular pattern disabled.
- Anything taller than 1200 mm, the "Rectangular Pattern" quantity should be 2. Which is produces only one more pattern feature.
- See video for a demo: https://autode.sk/3vRW8on
- Attached is the .f3d file
- From the parameter table:
- ThirdHingeCalcThen = sign(ThirdHingeCalcIf) + 1 (Use No Units)
- ThirdHingeCalcIf = d2 - 1200 mm
- ThirdHingeCalcDist = floor(( ( ( d2 / 2 ) - 100 mm ) - 64 mm ) / 32) * 32 //this calc is very complicated but the hinge couldn't be in the middle//
- Don't overlook the power of these built in functions. See a list of Fusion 360's functions here, you might find some other uses: https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-76272551-3275-46C4-AE4D-10D58B408C20
