Use the same design with different jointures
mypub
mypub
I need to create the same design twice but with different jointure. Basically, I need to mirror my construction:
I already use the derive every design from a single design to share the parameters between them. I don't know if it could be possible to keep both my front and back component in synch and just change the jointures.
jhackney1972
Could you attach your model?  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
mypub
Thank you for your reply, here are both my master file with the parameters and the construction file.
REgard,
jhackney1972
You mentioned you wanted to Mirror the assembly.  The best way to handle this is to create your mirror then select the mirror components and create a Rigid Group to take the place of the lost Joints.  If you want to place the assembly in any other manner, you could save it out as a sub-assembly and then insert it into the same or different assembly and it will maintain joints as a sub-assembly.
