[Under Development] Customizable Keyboard Shortcuts!!
excitive
Alumni Alumni
Message 1 of 60
excitive
We know you’ve been waiting for this folks! It’s one of the top 10 Idea Station requests. Comments, emails, tweets, letters written in blood… we get your requests from everywhere!
And I’m happy to share the news that we are working on it!
As an Experience Designer for Fusion, I would like to offer a sneak peek into the UI that our teams are working on:
As you can see above, a new section will be added to Fusion Preferences that will allow viewing and modifying all keyboard-accessible commands. We are working hard to make the navigation as simple as possible, so you can use it as a reference tool as well, that simply lists all available default shortcuts.
To modify or assign a shortcut, just click on it in the SHORTCUT KEY column and type the new one.
"Wait, what if I accidentally assign a key that already does something else? Will you crash my Fusion?” *frown*
Well no, we’ve got you covered. Fusion will immediately prompt you that there is a conflict, and you will have a choice to keep the either of the commands on that key:
Quickly wanna find a command? It will have a search box that will look through the ocean of all commands in Fusion and present matches:
Few notes:
  • Customizations will be synced with your Autodesk account, so you will get the same environment if you borrow your neighbor’s computer (don’t).
  • There will a button that brings back factory defaults. (AKA We told you so).
In future we are also planning two nifty little additions:
  • Print Reference Sheet – Will export a well-formatted printable file that contains a list of all commands that have a shortcut key assigned, custom or otherwise. You can use this file as a cheat sheet to improve your productivity. You can also print it and pin it next to your desk (save paper though).
  • Import/Export – Want your entire team to have same Fusion environment? Want to boast your ultra-productive shortcut set to your designer friends? This function will give you a file that you can send to other Fusion users and they can Import it on their account to get your customizations. Cool, eh?
That’s all I have for you now. Please let us know what do you think of this, and share any feedback and comments or features/points we might have missed.
Cheers!
Shekhar Somani
Autodesk Design
Replies (59)
Message 41 of 60
what happend? It's 2019 and it's still missing 😞
Message 42 of 60
excitive
Hello! We did implement this, however the design was changed along the way. You can customize the keyboard shortcut for any command by simply selecting the “three dot icon” next to any command in the toolbar menus.
Message 43 of 60
arcleveland
Can you do it for isolate, unisolate yet?
Message 44 of 60
alpineglobalprivate
Custom shortcuts have COMPLETELY disregarded the 'VIEW' type options, which IMHO are the most important!
User CUSTOMIZABLE shortcuts: in SolidWorks, I set E R T and Ctrl+E Ctrl+R Ctrl+T
for Front, Right, Top, with the inverse (Ctrl+) for Back, Left, and Bottom
We need [user customizable] shortcuts for:
'Normal to': N (which is a toggle: normal-obnormal-normal)(F360:Look at)
'Previous': P (with a history of previous views)
'Isometric': I (get back so you know where you are)(F360:Home)
'zoom Window': W (zoom in on tiny stuff, use P to go back to original view)
'Fit': F (just basic functionality in SolidWorks; the cube is VERY slow compared to a memorized key (of our choice))
Personally, I rarely use shortcuts for 'line' 'circle' etc, but having NO view shortcuts wastes HUGE amounts of time.
Any command for views (bottom of window/cube) are notably lacking shortcuts. Using MY selection of keys is crucial.
Thanks for the consideration.
-Christian
Message 45 of 60
alpineglobalprivate
How long will you tease us?
Shekhar Somani
Autodesk Design
It has been 1.5 years now and still no view commands shortcuts ability...
-Christian
Message 46 of 60
dieselguy65
I have all those shortcuts set to the extra buttons on my mouse.
Different views, top, home, left, ISO1, ISO2, etc.
Message 47 of 60
alpineglobalprivate
How? I cannot find any shortcuts for view items...
Message 48 of 60
I've been searching for those VIEW shortcut since I started using Fusion. It's insane there are no shortcuts for view points. Going to the view cube every time you want to have Front, top or side views seems ridiculous. I totally agree with you Christian. WE NEED SHORTCUTS please.
Message 49 of 60
opus1
Yes, I need it too......
ctrl 0 & crtl 1 for perpective and ortho........
For the key shortcuts of the views, you can find a 3dconnexion spacepilot. Okay, it's expensive, but so comfortable...;)
But a solution with alt0/1/2/2/3/3/4/4/5/6.... could also be very good.
PLEASE, PLEASE.
Message 50 of 60
GRSnyder
What I really miss is a keyboard shortcut for Look At. Not Look At as in the global view controls command, but Look At as found in the Sketch palette - the one that just reorients you square to the current sketch.
Message 51 of 60
boelZCKBD
Good! I have just found an annoyance that should be solved with a custom shortcut.
I'm on an AZERTY layout. In sculpting, I like to change my coordinate space when editing, but the shortcuts aren't that user friendly to an AZERTY user. They should be side-to-side, ALT X, C and V shows that. But what should be ALT+W for world space, is for me ALT + Z. I guess it is because my W is translated to a Z, which is located on another place.
Message 52 of 60
tannerellison3d
I am quite confused as to why the demonstrated keyboard shortcut menu was not implemented! It appears to be exactly what everyone across all the forums has been asking for and helps align the UI and UX a little more with other contemporary Autodesk products (particularly the massive flexibility of customization found in Maya/3D Studio Max/etc.) The shown prototype (from 2017 and apparently unused?!) also allows users some visibility into the available commands and how to have agency over their use. Please implement this feature as originally demonstrated 3 years ago!!!
Message 53 of 60
stephenbrucewong
Yes PLEASE!
Isolate and unisolate keyboard shortcuts as well as visibility shortcuts would save the most time by FAR when it comes to navigating through complex assemblies.
Stephen
Message 54 of 60
@excitive It's really great that you added the keyboard shortcut functionality using the three dot icon in the toolbar menus.  Thank you very much for that functionality!
However, there is still one glaring thing missing with keyboard shortcuts.  You guys really need to add similar functionality to the ViewCube.  First, being able to set a shortcut for the Home view is essential.  It would be nice if I could hover over a selectable point on the cube (Faces, Corners or Edges) and assign a keyboard shortcut to the selectable point.
Being able to use the three dot icon for all the options in the ViewCube context menu would also be great.  Additionally, if there was a 'Select View' section in the context menu with a list of the faces corners and edges that also used the three dot icon then selecting just about any view with a keyboard shortcut would be possible.
This would allow me to assign keyboard shortcuts to all the typical views I use, greatly increasing my productivity.
Do you guys have any intention of fixing this glaring omission to the keyboard shortcut functionality?  If so do you have any kind of timeline?
Thanks!
Message 55 of 60
This doesn't address that fact that basically ALL the view point and hide/show kind of commands DO NOT HAVE A three dot UI. So there's still no way to assign hotkeys to them.
My top requests are hotkey access for:
- Isolate/unisolate
- Look at (sketch)
- Unhide (ie, Solidworks has an unhide hotkey that reveals whatever hidden body is under the cursor, tap again to reveal successively more hidden bodies). So here is could be V (hide) and Shift-V (unhide) for example.
I also constantly frustrated that I can't select vertex thru other components. This only seems to work in special circumstances like when the fillet command it open, but there are so many more circumstances where having select-thru is useful.
There are so many other weird quirks/deficiencies, but these are the ones I've been ramming into most frequently in less than a week of using Fusion.
Lacking these fundamental usability aids makes me think the design team has never watched a ProE or Solidworks power user at work, and just keeps reminding me that I'd rather be in Solidworks.
Message 56 of 60
skarpovsGNG3A
Community Visitor
Community Visitor
2022
Message 57 of 60
alpineglobalprivate
WHEN? Do not forget a customizable 'HOME' view shortcut, not to mention ALL view cube 'clicks' (IE 'Front', etc.) AND the lower toolbar items, like 'Look At' (normal to, in Solidworks) and ZoomWindow, and any other commands without shortcut assignment capabilities.
The import/export will be MUCH appreciated, as will the 'Print Ref Sheet'. Suggestion: set a custom command as 'global' to assign it to ALL workspaces (without having to assign 'per workspace'). Glad to see you are finally doing this, as it will be much loved. Hope you release it ASAP, even if it is a beta choice. Thank you.
-Christian
Message 58 of 60
axalea_thomas
I'm working on an add-in that called Toolbar & Shortcuts Editor provides similar functionality to the one mentioned in the original post: https://forums.autodesk.com/t5/fusion-360-design-validate/new-add-ins-for-windows-toolbar-amp-shortc...
Thomas @ Axalea
My Add-ins (Windows)
⌨️ Toolbar & Shortcuts Editor: Assign any key (and some mouse buttons) as keyboard shortcut!
⤴️ Extra Shortcuts: Assign shortcut to Front, Home view, Look At, Activate Component and more!
My Logo: Put your logo in the Fusion window (for presentations and streaming)
 Axalea Notes - Annotate your model with notes
Message 59 of 60
Scoox
@axalea_thomasDo post back when that's ready for release (if you plan on release it, of course). I'm subscribed to this thread and will be notified of new posts. Thanks!
Message 60 of 60
axalea_thomas
@ScooxMy add-ins are now released in the Autodesk app store!
https://apps.autodesk.com/en/Publisher/PublisherHomepage?ID=QF2AP7A29Y9C
Thomas @ Axalea
