I have this assembly that has a rotary joint. The component is supposed to be able to rotate a certain range that is limited by 2 other components. When I enable all contact sets or ground the components that are supposed to limit its range of motion, the component becomes unable to move. Interference analysis reveals no interference. I have attached the project.
Solved by jhackney1972. Go to Solution.
Turn off contact sets.
Set approximate Joint limits, and fine tune it.
Might help....
Could you explain the expected motion a bit more. The Green translucent component is showing that it is suppose to be bolted to the bracket holding a pivoting lever. The green component seems to be the one you want to rotate when the pivoting lever rides on the V-Groove. If this is the case, it is an impossible assembly. Please clarify what you want.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
I want nothing to move except for the lever.
The motion of the lever should be limited by the PVC offset (the translucent part) and the bracket under it.
All the components except for the lever are supposed to be "rigidified". I removed joints/grounds/rigid groups trying to get it to work properly but I may not have added them back.
Is the movement shown in the animated GIF what you want? The lever is being stopped on the top by the PVC offset and on the bottom by the cross bar. If so, I will continue with a video or I can send back a F3Z file, which you probably do not want to deal with. Let me know.
John Hackney
Retired
I believe you only issue was that you used Enable all Contact instead of using a couple of Contact Sets. Please do not forget to Accept Solution or ask further questions.
John Hackney
Retired
Thank you for your time and your great explanation John! I was able to get it to work properly by following your video.
