Solid Meshing Error: "No Further Information"
Message 1 of 10
I am attempting to run an stress analysis on a solid model made from a scanned 3D model. However, whenever I try to generate the mesh I get the error shown in the images: "Meshing Error! Phase: Solid Meshing. Description: No further information".
Because of the "no further information", I don't even know where to begin with fixing the problem. For reference, the large number of triangular faces is a result of converting the 3D-scanned surface mesh into a solid model, and the irregular faces are the result of manual corrections to the model.
Replies (9)
Message 2 of 10
TheCADWhisperer
Message 3 of 10
Okay, the file is attached.
Message 4 of 10
TheCADWhisperer
I would use the scanned data only for reference (preferably with a set of calipers for measurement and the actual item) to remodel rather than try to mesh this geometry.
Looks like about 3-5 hrs of work should return a model appropriate for FEA.
Message 5 of 10
Is there any particular reason why meshing this model is a bad idea?
Message 6 of 10
TheCADWhisperer
Here are just a few of the issues.
Message 7 of 10
Ok thanks, I didn't know there were that many problems with it, and I now understand why you recommended remodelling it from scratch. My problem now is that I almost certainly will not be able to accurately model all of the curves. But if I can't use this scanned model directly, there's no other option it seems. Thanks again!
Message 8 of 10
TheCADWhisperer
Just using the scanned model for reference - you can model a far better model that is good enough for FEA.
I don't think you need a model accuracy that you might expect.
If you need a precise model then you are a country mile away with this faceted rubbish.
What is the material?
What type of analysis?  Linear or non-linear?
Message 9 of 10
Okay I'm pretty new to FEA, so I guess I'm not sure how accurate a model I actually need. To try and answer your questions: it's Aluminium (probably 6061), and I think a non-linear analysis? I know I want to do a dynamic stress/strain and modal (vibration) analyses at least. I have Nastran In-Cad in Inventor 2017 if Fusion 360 can't handle that sort of simulation.
Message 10 of 10
michaelpetri14
Hi TheCADWhisperer -
I'm having a similar issue and am trying to diagnose what's specifically wrong. I don't see any "odd" surfaces on my model like what you've highlighted in your video. Did you use a particular tool to diagnose the model and highlight certain surfaces in red?
Any help would be appreciated!
Michael
EDIT: I'm attaching the file I'm working with (the top jawbone of a grizzly bear, actually). And the specific face I know I'm having trouble with is colored in red, middle of the left portion of the top surface. Screenshots:
