Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Sketch on top of the gear/circle
5 REPLIES 5
peenzano
515 Views, 5 Replies
Hi there,
I would like to reproduce a gear with kind of clutch on top of it. It has like a teeth where another part comes in and make slip joint.
As for the gear, I have already did it using kind of generator for gear.
The problem is with the teeth. I was trying to sketch on top of the gear, then extrude it and use draft - didn't work.
Then I was trying to sketch at the side of the gear but that didn't work for me as well.
Is there anybody how can point me in the right direction? How to sketch it?
Photos and part of the project attached.
Labels (3)
5 REPLIES 5
g-andresen
in reply to: peenzano
maybe this could work
Screencast
günther
peenzano
in reply to: g-andresen
Thanks Günther, we are almost there, but not quiet.
The triangles (red arrow) are not the same dimensions.
The outer one is bigger than the one inner one.
That cause the face (yellow arrow) to be at some angle.
Do you know how to do this?
g-andresen
Perhaps this one will meet your expectations.
Screencast
Dimensions would have to be adjusted.
günther
peenzano
It meet 100%
Thank you one more time Günther.
I learn a lot from you. Especially using projection and intersect!
g-andresen
I'm glad I could help and hope you continue to enjoy Fusion.
günther
