Sketch lines with formulas
tcooms
tcooms
I wanted to know whether it is possible to define a formula or equation to describe a line or path as a sketch?
Since Fusion makes use of a double axis plane, it would be really handy to use these formulas to design more exact.
I wanted to create a perfect parabola using the fomula y = x² within boundaries like for example x = [-10,10] and y = [-10,10]. That way I can create the exact path I want for a certain line.
I also wanted to try it out for more complex formulas using y = a*exp(x) or y = x^n (n is a rational number) etc.
Thanks in advance!
Kind regards,
Ticho
cekuhnen
@tcooms To my understanding not in sketch directly
but u could write an add on that based on the foruma makes that sketch
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Beyondforce
@cekuhnen is right. You cannot do that directly like in Blender.
But, you can achieve what you want, by inserting your formula into a Python script, if you know how to code. This way, you can create a plugin that creates the geometry that you want, where you want it.
If you need help with Python scripting, this is the forum for that: https://forums.autodesk.com/t5/fusion-360-api-and-scripts/bd-p/22
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
