What is the Best way to add a cover to this body?
ecam6P6WJ
ecam6P6WJ
Hey,
I do have a sketch off my building. I have extruded is like seen in the picture. What I always wonder is how do I get a cover at the top and bottom of this body. I would like to use the outer Couture for that. Do I really need to add a new sketch make a projection and so on..
Is there a way to draw a box and cut away with the outer Couture?
I hope you under stand what I mean. My goal is to draw my house in Fusion 360 for 3D printing 🙂
many thanks
cheers
mathias
TrippyLighting
I would create a new sketch on the top wall surface.
By default auto projection is enabled ( its' not in my preferences) , so you don't have projects things manually.
That auto projected profile can directly be extruded.
JDMather
Have you modeled 1:1 scale?
How thick are your walls?
What is the build envelope of your printer?
ecam6P6WJ
Why do you ask. The walls is not my problem I know that I cannot print them in the right size. I would be great if there is any tool in the future to help here.
But do you know a good solution for my question?
many thanks
ecam6P6WJ
Okay thanks i will try that?
