Sheet Metal - Cut function
RasmusBredal
RasmusBredal
As an Inventor Geek i misse some Cut funktion.
Cut Across Bend and Cut Normel.
Need some hove to make 90° cut angle on flatpattern.
FusionSMCut3.pngFusionSMModel1.pngModel Insperation - @PaulMunford
Replies (7)
RasmusBredal
PaulMunford
Great job 🙂
Could you split the face and then thicken > cut?
There's a graphic which explains the technique in this article:
http://graitec.co.uk/blog/entry/autodesk-inventor-sheet-metal-flat-pattern-success-every-time
Let us know if that helps!
Paul
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
RasmusBredal
Thanks!
Thicken wont work on SM surface, but I forund a work around.
promm
@RasmusBredal,
Please use the Unfold and Fold features to cut across bends.  First unfold, then sketch the geometry that you would like to cut, extrude your cut and then refold your model.  Inventor and other tools have multiple ways to cut across bends.  Based off of user feedback and research, I chose unfold and fold as our solution to cutting across bends.
Cheers,
Mike Prom
Hi Mike,
I have been looking for a solution to this as well and while flatten, cut, bend-back will create a normal cut this is severely limiting during design and often ends up creating mis aligned cutouts or improper shaped cut outs.
I hope this is only a temporary solution and Autodesk is working on a way to create these cuts while in the 3D space
Jack
miechh
Yeah, it's 2022 meanwhile. I came across this youtube video from Clough42 (https://youtu.be/05s9u9GIaCY?t=443) in which he wants to cut out a profile through a bent part. I was shocked to see what he had to do to accomplish a proper cut (with cuts normal to the sheetmetal faces). I thought he was unfamiliar with a function in F360 and to find out myself that there's still no proper function in Fusion 360 to create those cut-outs I was pretty amazed. I'm also an enthusiastic Inventor user and there we have this nice function "Cut normal" which cuts through a bent part in such way that the profile you cut out goes straight through the bent part without touching the workpiece but with all cutting walls perpendicular to the faces of the sheetmetal part.
This 'workaround' mentioned above (which shockingly dates back to 2017/2018) which describes unfolding, projecting geometry, extrusion cutting the profile again through the part and refolding, is something that Inventor 2017 didn't have anymore, and that's almost six years ago. It's about time the Sheetmetal-team of F360 implements this Cut Normal function. Sorry, don't want to be negative.
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 10 Professional (64bit)
gl_saccardo
Community Visitor
Community Visitor
I purchased F360 hoping that this feature would be standard in the paid version, but I'm still looking for alternative solutions.
Autodesk certainly knows how to implement normal cutting, if they don't I think it's by choice.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
