Scaling Question
Scaling Question
Hello everyone, I have a simple question,
How can i scale just only that side?
Sorry i don't know what or where to start or name the keywords to search.
HughesTooling
Not sure exactly what you're asking, are you trying to make the part bigger at that end? You can't scale a single face, you'll need to edit the sketch you made the body with or you could try using Draft from the modify menu.
Mark
Mark Hughes
Owner, Hughes Tooling
Thank you for reply me.
Yes, i try to scale that face bigger. I though i can scale just one face like 3DS Max or other 3d software.
Tu.
You could convert the body into a DM Feature. Right click the body in the browser and click convert to DM feature. It will delete the timeline for that body and it will all change to a single icon. Right click that icon in the time line and click edit. You will then notice if you go to the modify drop down you now have edit face. From there it works just like t-splines.When you are done click finish base feature at the top. You can go back and edit it as many times as you want.  Honestly I would avoid this unless you don't have a better choice because you loose your time-line for that object.  If you decide to go that route at least make a copy of the original body first.
If you need more specifics or need help with it let me know I can screen cast it.
Hope that helps.
Wow, this is really help. Thank you, now i guess i have to find more tutorials. Smiley HappySmiley Happy
Tu.
