Question about Design Workflow
wordwrap
Message 1 of 11
wordwrap
I have defined a new component (lets name MASTER) and designed a sketch into it.
Now I want to modify and/or extend the design, but keep the original.
Therefore I copied the component to a new one (lets name SLAVE  1)
The problem I have is that all my modifications in the sketch in SLAVE 1 are automatically applied on MASTER, as if they are linked together.
I think it should be possible to prevent this and create a real copy
But  .....  the other way around ..... when I make a change in MASTER, it should be transfered to all the SLAVES
Is this a stupid idea????
Replies (10)
Message 2 of 11
g-andresen
use Copy > Paste New instead!
günther
Message 3 of 11
wordwrap
Thank you for your reply!
Can you tell me where to find the Copy New in the list?
Message 4 of 11
Bunga777
Right-click on a component in the browser.
However, only components other than the source component can be copied.
Message 5 of 11
g-andresen
Watch the sreencast
Tip:
When editing the sketch in component 2, the display jumps to the location of the sketch origin in component 1.
For better clarity, if you have little experience, you should then deactivate the 1. component (Temporary ).
günther
Message 6 of 11
TrippyLighting
günther
That does not fully address the issue because the OP still wants changes to the master to flow into the slaves.
Message 7 of 11
jhackney1972
Take a look at this Blog Article and Video.  It will allow independent Slave changes as well as Master to Slave updates.
John Hackney, Retired
Message 8 of 11
TrippyLighting
A simple copy/paste of a component creates a component instance. It is basically a pointer to the component data, which only exists once.  If you change anything in either component it changes both component instances.
A copy/paste-new created a new completely independent component, resulting in twice the memory consumption.
The advantage is that now bot components can be edited independently. There is no Parent/Child relationship!
To do that, you'll create the master component and create your base sketches and base 3D geometry.
Then you create a new, empty component and copy the  body from the Parent component into the new Child component. Use the Boundary fill command in the Surface tab for this! Do not use the traditional copy/paste function.  (the copy paste function cannot be edited to re-select a body. Boundary fill can be edited).
You can now edit the ne Child component independently from the  Parent.
If you change dimensions on existing sketches , or dimensions/parameters of existing  features in the Parent component, they will propagate down the timeline to the Child component.
If you want to add new features to the Parent that you also want to have in the Child, you need to roll the timeline back to before the Boundary Fill command. than make the changes and roll the timeline back to the end.
Message 9 of 11
Bunga777
I am sorry that I did not quite grasp the purpose of your question.
I will explain my interpretation, and I apologize if it is covered by others.
The workflow you mentioned can be achieved by copying and pasting bodies and manipulating the timeline, and that is how I use it in my work.
Here is Body1 created, Body2 duplicated from Body1, and Body3 duplicated from Body2.
Operations performed prior to each copy operation will ripple through to subsequent copied Bodies.
For example, if you roll back the history to before creating the first copy of Body2 and then make changes, the same changes will be made to all subsequent copies of the part. As a test, here is the result of inserting a drilling feature before copying.
If you move the timeline back to the position where the middle part was created and make changes, only the parts after that copy will be modified.
If changes are made at the end of the history, only the last part will be modified.
In other words, this history operation is creating a derived part.
Of course, if you change the first sketch in the history, the shape of all the parts will change because it is the history before copying.
This phenomenon occurs even after copying and converting to components, so it is possible to create derived components.
Message 10 of 11
wordwrap
The key to the solution was your remark …..  “However, only components other than the source component can be copied.”
thank you! Everything under control from now on
Message 11 of 11
wordwrap
This is exactly the process I was hoping to find.
thank you so much!
