I can not figure out why a line turns into a spline after performing a projection.
1) Select Create Sketch and picked the front surface of the Duct. (Sketch33)
2) Select Project and choose the outside edge of the profile.
When I delete the Projection symbol the projected line turn into a Control Point Spline. I am expecting the projected lines to turn into non-projected sketch lines and arcs. Because the sketch was created on the Duct's front surface all the lines should be in a single plane which would not result in a spline. What am I missing?
Link copied
