Projected line segments not connected
nkloski
Message 1 of 36
nkloski
Hi!  I have a solid body I imported from another source, and Fusion converted it just fine.  When I project the outline of that body (either as "include 3D geometry" or just a normal projection down to a flat plane, some of the segments are connected, and some are disconnected, like this:
I can break the link and probably do it that way, but that breaks the parametric-centric design.  Anyone know why, in the original object there is an oval, but in the projection, some of the intersections are not carried over?
(unfortunately, I can't share the model as it is under NDA, but I have seen this happen on other models before as well)
Thanks!
Nick Kloski
Replies (35)
Message 2 of 36
etfrench
I've had the same issue with models created in Fusion 360.  My current fix for all Fusion 360 bugs is to change the display precision to maximum in preferences Smiley Surprised  (Actually, restarting Fusion 360 is usually the first).
Are there other faces on the imported model that come close to the projected lines?  If so, try projecting those as well.
ETFrench
Message 3 of 36
paul.clauss
Hi @nkloski
Thanks for posting! It looks like you are experiencing an issue in which projected geometry from an imported solid is incorrectly generated in Fusion 360.
What file format was this part imported to Fusion 360 in? What workflow did you use to import the part?
I am happy to log an issue for this behavior with our development team! However, I need access to a file in which I can consistently reproduce the behavior you are experiencing. Is there any way you could share the design with me as a public link in a private message? Or could you share any of the other designs in which you have observed this issue?
Please let me know if you have any questions - I'm happy to help!
Paul Clauss
Product Support Specialist
Message 4 of 36
nkloski
Happy to provide!  I chopped and sliced up the NDA file into something that is non-NDA.  This is the bottom part of the file I was talking about, and the Fusion file has two projections in it, both not working.
One is "include 3D geometry" which shows disconnections, and the other is a straight projection to a plane.
This was a STEP file which I hit the "upload" button in Fusion, and it converted the file to a Fusion design.
Thanks!
Nick Kloski
Message 5 of 36
paul.clauss
Hi @nkloski
Thanks for sending the example file over - I was able to reproduce this behavior and have logged a report with our development team (FUS-31813). We will be looking into this issue - we appreciate you bringing it to our attention!
Unfortunately, I have been unable to find a workaround for this behavior that does not involve breaking the link on the projected sketch profile - it is necessary to edit the sketch in order to correct the discontinuities. I would recommend breaking the link and using the extend command to work around this for now - I apologize that you will not be able to maintain the parametric properties of the projected sketch with this workaround.
Please let me know if you have any questions - I am happy to help!
Paul Clauss
Message 6 of 36
nkloski
Ok, thanks for escalating this.  I will do as you say until this issue is resolved....
Nick
Nick Kloski
Message 7 of 36
nkloski
Ack...now it is happening on another imported model.  Breaking the link and extending the sketch does not result in fully connected profile.  It "looks" connected with black dots, but the entire line is not connected, disallowing me to perform loft commands between the "included 3d geometry" profiles.  Any word on this?  thanks
Nick Kloski
Message 8 of 36
paul.clauss
Hi @nkloski
Thanks for posting! Bugs logged with the development team will be addressed in future updates to Fusion - unfortunately I cannot give a date on when this issue will be resolved.
Can you make the segments continuous by breaking the link and then making the endpoints coincident? I am happy to have a look at the new model and pass it along to the development team to further investigate this issue!
Please let me know if you have any questions.
Paul Clauss
Message 9 of 36
pavmed
Hi!
Would like to "up" this topic. Spent 3-4 hours jumping around my sketch with projected geometry from STEP file until found this thread. 🙂
Any chances this issue in "to do" list?
Message 10 of 36
nkloski
Sadly, I still deal with this issue as well 😞
Nick Kloski
Message 11 of 36
cekuhnen
@paul.clauss @nkloski
This is because of issues in the sketch engine.
To be honest it has many more deal breaker issues.
To my understanding they are aware of the issues however focus development on other serious 2D problems in the engine
to produce a better foundation when dealing with those 3D sketch problems. Makes sense - still sucks because some tools
are there in Fusion yet work not always correctly.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 12 of 36
could you please explain how to adjust display precision in Fusion360?
Thanks!
Message 13 of 36
etfrench
Preferences|Unit and Value Display
The number fields don't expand when more decimal places are selected in Preferences.  The left side of an number field will not be displayed when more than 3 decimal places are used.  It's there, but you have to scroll withing the text box to see the numbers.
ETFrench
Message 14 of 36
angrdnsr
I see this issue has been discussed before.
I am having similar issues.  If I sue Derive to insert a sketch from a previous drawing into a new design, and then use project to create a new sketch using features of the drawing, the resulting projected lines are not all connected.
One side of the sketch is fine and I can use Loft, the other is not connected?
This is an incredibly frustrating feature of fusion360
Message 15 of 36
TrippyLighting
I use extruded surfaces and surface edges for lofting.
Even if the sketch segments would be connected, projected sketches in many cases create splines with broken curvature.
Message 16 of 36
angrdnsr
That's fine for a temporary workaround.
So not connecting projected line segments is an issue with Fusion 360 that should really be fixed?
Message 17 of 36
TrippyLighting
@angrdnsr wrote:
That's fine for a temporary workaround.Absolutely should it be fixed!
Absolutely should that be fixed!!!
It's a known issue and i's been a known issue for quite a while.
Another workaround is to do that same projection in Direct modeling mode just to find out that in DM mode it works (at  least in some instances). That is actually how I found and reported this. But I am not the first one to report this buggy behavior. I just reported that there's a difference in behavior between DM and TL mode.
I had downloaded another user's design and it was created in direct modeling mode, without a timeline. I started modeling to help with the issue and the projection worked fine. Then I noticed that the timeline was turned off.
So I started from scratch with the timeline enabled and the projection did not work.
I checked that back in DM mode and repeated a few more times just to be sure this was reproducible. Then I reported the bug.
Message 18 of 36
Three years and counting ....
I broke all my links but can still not use the extend tool. How come?
Message 19 of 36
So the projected purple line issue is annoying.  Can get some stuff to work but other times, nope.
My quick solution is to export the sketch as a DXF.  (Place a reference cross in sketch for your export.)
Open file in Adobe Illustrator.  Confirm scale and then use the Compound path/Make (Ctrl=8) command.  Under the Object menu up top.  Then export as a dxf again.  Then go back to Fusion 360 and insert new dxf.  At that point select dxf and move it to the plane and point of the original dxf.  Using the Move/Copy-Move Type point to point tool.  This is why you needed the reference cross added in you sketch.  You'll have a working sketch you can extrude from at that point.  Its a lot of little hoops to go through but it work.  And geometry is correct as far as I can tell.
Good luck.
It will be part of my new workflow now.
Message 20 of 36
djohnson9YW8F
I agree that this needs to be fixed. For the purpose of being able to grab a quick cross-sectional surface area from a model. It sure would be nice to have a solution instead of a workaround...
Unfixable?Unfixable?
