When making the joint, the component stays on the original place, while the joint origing goes on the right place.
Solved by bart_k. Go to Solution.
Yes,
What is grounded?
Blue plate is not a Component.
Sooo many Joint Origins, use the component snap points, and the Joint Offset Dialogue.
See if this helps.
Might help...
In Fusion 360, grounding is only local to particular design. So you might ground Component3 in the Caster, but once you insert the Caster into the Karretje the design it floats again.
The most reliable way to assemble all the parts in the Caster is to create a rigid group joint. The rigid group joint does not require you to select geometry, but locks the origins of all involved components in place. The rigid group should also include the top level origin.
We know that in reality that wheel rotates when the caster rolls over a surface, but in CAD it is rather useless to apply a revolute joint as it does not add essential functionality to the design. If this would be a hinge, for example, that would be different.
Also, because you are not actually creating any geometry in the Caster, and converting the bodies into components is not adding any functionality in this case., there is no reason to enable the timeline.
That keeps the memory footprint of your designs up to factor three smaller.
As @davebYYPCU stated, in this case I would not use any joint origins. I would use the center of the mounting plate of the caster as a snap point for a joint.
The other "issue" that @davebYYPCU was trying to explain is that the base plate is a body in a component group/assembly. From a pure assembly standpoint that will work, but if you want to create a functioning BOM, it wont, because that base plate is not it's own component. It will show up as geometry in an assembly drawing, but you won't be able to balloon it and it won't be listed on the BOM.
That the blue plate is not a component - I was not able to Joint to it, (unselectable) until it was converted.
Might help.....
What is grounded? it doesn't matter here
Blue plate is not a Component. it doesn't matter here
Sooo many Joint Origins, use the component snap points, and the Joint Offset Dialogue. Good Suggestion
I really want to use the caster assembly as linked file, i don't want to embed it.
I did found the solution myself: the joint origin may not be on assembly level but on the level of component3.
Joint offset could be a better alternative.
