Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
presspull problem
8 REPLIES 8
Message 1 of 9
daniel_lyall
825 Views, 8 Replies
presspull problem
daniel_lyall
removed
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
presspull problem
removed
Daniel Lyall
The Big Boss
Mach3 User
8 REPLIES 8
Message 2 of 9
Mike.Grau
in reply to: daniel_lyall
Mike.Grau
Hi @daniel_lyall,
Thank you for the update.
I guess that the "press pull problem" has been resolved through an update?
Could you may share the link to the initial post about the "press pull problem" that we can share this
information with the users?
Hi @daniel_lyall,
Message 3 of 9
daniel_lyall
in reply to: Mike.Grau
daniel_lyall
@Mike.Grau
it was a not knowing how to do something problem.
I got halfway through typing out what the problem was and I worked out what to do. I can add a screencast to show what the problem was is
Daniel Lyall
The Big Boss
Mach3 User
@Mike.Grau
Daniel Lyall
The Big Boss
Mach3 User
Message 4 of 9
Mike.Grau
Mike.Grau
Hi @daniel_lyall,
Thanks for the update.
Yes, that would be great, so other user can benefit from this post.
I´m looking forward seeing your screencast
Thank you for your help,
Hi @daniel_lyall,
Message 5 of 9
daniel_lyall
daniel_lyall
@Mike.Grau here you go file attached as well it is only a play file not important, the screencast shows what I could not do and what I had to do to do what I wanted to do.
I think it's a bug as well sometimes it would work
Daniel Lyall
The Big Boss
Mach3 User
Daniel Lyall
The Big Boss
Mach3 User
Message 6 of 9
Mike.Grau
Mike.Grau
Hi @daniel_lyall,
Thank you for sharing the screencast and your design, this is really helpful.
I have the feeling that this is not directly a bug.
The conical surface can´t be considered for the extrude feature since the conical surface can´t be extended
logically in the background by the extrude tool. I have extruded the surface manually and created the extrusion afterwards.
Here is the public link to the test file I have created for you: http://a360.co/2bi3JTr
I will get in touch with the Fusion 360 development team and we will discuss about it.
I hope the file helps.
Hi @daniel_lyall,
Message 7 of 9
kb9ydn
kb9ydn
If you can extend the surface manually though it seems like Fusion ought to be able to do the same thing for an extrusion to surface.
And FWIW I was able to do something like this in Solidworks, so it's at least possible.
C|
C|
Message 8 of 9
daniel_lyall
in reply to: kb9ydn
daniel_lyall
I was able to do what was needed it's in the screencast, I just did not show the last bit. I just added in the rod to show it does not work on a solid.
@Mike.Grau thanks mike not quite what I ended up doing, it was just a play to work stuff out. the solid rod, if the sketch extended past only one end it works when it extends past two ends it fails. and if you toggle match it fails and works sometimes.
@kb9ydn it can be done like your pick you just add a draft
Daniel Lyall
The Big Boss
Mach3 User
Daniel Lyall
The Big Boss
Mach3 User
Message 9 of 9
Mike.Grau
Mike.Grau
Hi @daniel_lyall,
Could you perhaps share with us more information what is the final step you made which was not included in the video?
Thank you,
Hi @daniel_lyall,
Thank you,
