Hi
I’m just finished creating my own gripper with a little modification. The design makes the two grips be possible to move on slide direction. The maximum range of both grips are 108/2 mm.
This forum is used by most users to receive help from more experienced users. If you jsut wanted to share your experience, that's also fine!
In either case, though, we'd need to see at least a screenshot of what you have designed 😉
The best feedback you'll get - assuming that's what you are looking for - is when you share the model. For small, self-contained designs the easiest way to do that is to export it as a .f3d fike and attach it to your next post.
