Placing a twisted wire circle model on a cylindrical object.
g.isley
g.isley
I am trying to place the twisted wire circle on a ring ( or cylinder ) surface.  See enclosed file.  I would like to have all of the model protruding the same height on the cylinder.  I saw one possibility using the sheet metal function which I have no experience with.  Any help would be appreciated.
Replies (25)
g-andresen
Hi, yes it´s possible with sheet metal tools.
Take a look here.
günther
g.isley
Thanks for your help. I don’t think outlining the profile with a spline then building the model with revolve would work here. My twisted wire circle is more like a thread, at an angle. I would not know how to do this in or out of the sheet metal environment.
etfrench
Is this what you want?
If so, open the attached file and walk through the timeline.
ETFrench
g.isley
Yes exactly.
g.isley
Thanks.  I'll work through it and hopefully understand the process.
g.isley
Is it possible to do a screen cast with voice.  I could not figure out what was going on.  Thanks.
etfrench
Sorry, no voice.
The bottom portion of the screencast shows the commands and dialog boxes when you view in the forum post (not full screen).
ETFrench
g-andresen
just a little note:
The procedure of @etfrench  is what the solution in the linked thread represents.
Your design, however, should be positioned in very precisely* height on the unfolded cylinder.
günther
* screencast at 5:12
g.isley
Absolutely fabulous.  Thanks you.
I would like  to pattern the twisted wire circle, say 4 circles, around a point.  Then repeat the 4 circles pattern around the ring.  Would that be the same as patterning in the model environment, or different?
etfrench
Yes, the first would be a circular pattern, the second a rectangular pattern.
ETFrench
g.isley
I noticed in etfrech's screen cast he clicked on the component and the entire history was still available.  On my machine I only have the history of the component.  Also all components are visible.  In
 mine the ring is a shadow and the component is visible.  How do I change that?
Thanks.
g.isley
Would it be possible to get the .f3d file of your screen cast? Thanks.
etfrench
It's attached to my first post.
ETFrench
g.isley
I was confused by the timelines being different.
g.isley
I can't seem to trim the circle after I have used the trim command.  I can't break the circle.
  After I have projected the outer and inner circle and drawn the lines.
etfrench
In order to trim (or otherwise change) a projected item, you must first break the link.  Right clicking on the item will bring up the context menu containing Break Link.
ETFrench
g.isley
Sorry for my densitude.  So I create a new component , create a sketch picking the side of the ring, Then hide the ring and call up project  and pick the inner and outer rings, then select ok.  Next two lines from the center to the outer ring and dimension them  .05mm apart.  Where is the link and what is it linked to?
etfrench
Projecting a line or curve (or other geometry) creates a link between the geometry and the projected object.  A projected object will be purple.
ETFrench
g.isley
I tried to simplify and create the same design.  It partially worked except I quadrupled the thickness of the ring.  The design was added to the sheet metal ring not my original ring.  What did I do wrong?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
