Parametric modeling
Parametric modeling
potlsnekkeri
Parametric modeling
potlsnekkeri
Hello
i have tried to use parametric designe in her but when i change the heigth of the cabinet the door dont change.
is there a way to fix this ,it yes can someone show me
https://a360.co/3UBNyqj
davebYYPCU
Sure, connect white point here to purple point.
Skap:1 Sketch 1.
Fully defined sketches work really good with Parameters, blue lines and white points are not fully defined.
Bunga777
Fix it.
I added it because a few restraints were missing in a few sketches.
Both are bound by Collinear and Coincident.
Since totalhøyde is assigned to konvolut.sketch1, other sketches will follow if they are constrained to match the totalhøyde sketch.
skap.Sketch1
bakplate sketch1
Note that while the lines in the sketch are blue, their positions are not fixed.
It would be a good idea to add dimensions and constraints so that all the lines in the sketch are black and fixed in their original positions.
I took a video. Please refer to it.
https://knowledge.autodesk.com/community/screencast/5f7f907c-e69d-450b-bc4f-c930da9f3574
potlsnekkeri
Thanks alot
how is the best way to use parametric designe and make 4 cabinets so that can fit into a length of 3340mm ?
g-andresen
just take a look at this thread (#6)
günther
davebYYPCU
Make one, 3340/4 long,
Rectangular pattern 3340/4 spacing.
count 4.
Might help....
