Surface patch modeling, Pinching/uneven
alex.martin.watson
Observer Observer
alex.martin.watson
Observer
Observer
I am trying to create a smooth organic shape. I have created a wire frame that's shape cannot be changed much due to design requirements. I then used the surface patch tool to patch all the edges. All connections on the wire frame are tangent to each other and I have made all surfaces follow curvature and/or be tangent to other surfaces.
With all this, I cannot find a way to get rid of the pinching/sharply uneven surfaces at the corners of the surfaces.
Does anyone have any ideas on how I could go about smoothing these all out?
I've also attached fusion 360 file as it may be easier to see what's wrong from there.
Any help would be greatly appreciated 🙂
davebYYPCU
Try Loft, I used the outline, to the top centre point, with 4 quadrant rails.
The short rails are not helping due to their own shape.
The outline could do with some work here.
Might help......
alex.martin.watson
Observer
Observer
That's done it! Thank you 🙂
I had not thought of creating a loft to a single point before, so thank you for the new technique.
