Opening STL file in Fusion 360
dhalpe.1855686
Message 1 of 8
dhalpe.1855686
When I open a STL file Fusion 360. I find that the model is 10x times the original dimension. I tried different option of opening the model in fusion 360. But same result.
Please advice
Replies (7)
Message 2 of 8
hfcandrew
Check your units. mm vs cm
Message 3 of 8
dhalpe.1855686
Thank you for your reply
I checked the Units they are in metric (mmNs). I verified the same in meshmixer.
Please let me know if you need the stl file.
Message 4 of 8
hfcandrew
Sure attach it. What dimensions should it be?
Message 5 of 8
TheCADWhisperer
Message 6 of 8
dhalpe.1855686
Please find attached herewith is the model. Dimension 50mm*50mm*55mm.
Message 7 of 8
TheCADWhisperer
@dhalpe.1855686
Did you figure this out.
STL is unitless.
So depending on the units the original designer used - you have to set the Units.
In some cases you may need to Scale - so use Insert Mesh rather than Open stl.
Message 8 of 8
dhalpe.1855686
Thank you very much for your help
