Sizes change when I import a dwg/dxf
Ryan_Fab
Ryan_Fab
Hi Everyone. Ive come across an issue this afternoon where the sizes on a file change once ive imported it into Fusion. The easiest way to see this is to check the 10mm hole centers on the attached file, in autocad they are 58 but they import at 58.23mm
has anyone seen and overcome this?
Ive attached the file
whittakerdw
There is no file attached. What software was used to make the dwg/dxf?
Ryan_Fab
Ive solved this myself. Turns out there wasnt an issue.
Within dimstyle, the creator of the dwg had set the precision to 0. rounding it down. Fusion was telling me exactly what it was
