I did an offset on the green line and got the 2 blue lines. I expect that if I double click on the currently selected darker blue line it will select it continuously but it looks like even though the green line is continuous the offset line is not.
I am not entirely sure how to solve this and make the blue line continuous. Even if I zoom in fully on to that white dot it looks like only one dot so I cannot connect the two lines to make it continuous. Sometimes I can work around it by extending the line but it does not work this time.
What could be the solution here?
Please attach your model as we do not know what you have placed in your sketch. Open the model in Fusion 360, select the File menu, then Export and save to your hard drive. Attach the file to a reply using the attachment section.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
