Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Non-Linear Plane Cut - help with how-to?
2 REPLIES 2
287 Views, 2 Replies
Hi Guys,
I've downloaded Fusion 360 tonight by way of Hobbyist access. I will eventually go through and learn how to use the program to create my own items, however tonight through a little bit of Youtube help and a little bit of fumbling around in the dark, I've worked out how to;
Import an stl
Rescale that stl
Cut that stl in half
Resave both halves of that stl, as stl files so I can whack them into the Cura Slicer for printing
What I can't seem to work out though, is how to make non-linear cuts into a model. My model has a hex pattern and I'd really like to be able to make the cut along the area where the hex edges meet (so a kind of zig zag cut), rather than just just hexes in half.
Could someone kindly point me in the right direction in how to go about this, please?
2 REPLIES 2
g-andresen
try this:
1. convert to Brep
2. creat sketch with "cut lines"
3. cut body
cut bodycut body
günther
in reply to: g-andresen
Thanks for your help Guenther, much appreciated...I'll give this a try!
Technology Administrators
