Need guidance on using extrude on a curve
stimike
Message 1 of 14
stimike
As the titel states I am attempting extrude on a curve shape. I and making a letter for a sign and I am cutting channels for LED strips inside it. The straight surfaces work just fine but any curves won't work. Not sure what I'm doing wrong. Thank you in advance. I am new to Fusion360 so still learning.
Channels work fine until theres a curve.Channels work fine until theres a curve.
Replies (13)
Message 2 of 14
aliobidi
Hi ,
can you attach your file with a pic of what you mean
Message 3 of 14
hamid.sh.
If I understood your requirement correctly, there are several ways to do this, e.g.:
1. Make s sketch at an offset plane and use Intersect to get the profile and use it for Thin Extrude (adjust Distance, Wall Location and Thickness to get the cut you want):
2. Make a profile of cut at a cross section plane (again Intersect helps) and use it for Profile of a Sweep together with edges selected as Path:
I have included both in an example file attached.
Hamid
Message 4 of 14
barry9UDQ6
Personally I like using combine-cut for stuff like this. Where you model up the full negative shape as a solid and use it to create a cavity. As if you were creating a cavity mould?
Message 5 of 14
g-andresen
The easiest way to do this is with an offset extrusion as shown in the screencast.
But why don't you share your design as @aliobidi  recommended?
günther
Message 6 of 14
stimike
Hopefully this is what yall are looking for to download. Thank you again
https://a360.co/3LHaq35
Message 7 of 14
stimike
Attached is the f3z file
Message 8 of 14
g-andresen
here is my version transferred to your file
Screencast
günther
Do not turn off the history.
Message 9 of 14
stimike
Thats exactly what im looking for. Ive only been doing this for about a month so still learning. Ill have to watch your video a few more times but that was perfect. Thank you  as well to everyone else
Message 10 of 14
hamid.sh.
This I did based on my first suggestion:
Hamid
Message 11 of 14
stimike
At the 0:26 sec mark i cant see what you did to make the design flat again.
Message 12 of 14
g-andresen
I projected your body.
Have a look at the timeline
günther
Message 13 of 14
stimike
Got everything to work. Ill probably have more questions as to why certain steps were done just so that i understand the reasoning. That way i can apply that to future designs. Thank you!!!
Message 14 of 14
g-andresen
I made the projection just to demonstrate the process of extrusion with offset on an unprocessed object, and at the same time use it to create the channel profile.
günther
